View Hidden Lines in the Elevation Viewport
As of my tries to publish my elevations to pdf, I want to view my elevations in hidden line mode, and wanted to know how can i do that.
thanks
10 REPLIES 10
Myles wrote:
Also how do you show the window and door markers?
Thanks
Myles
In order to show Door/Window Markers in Elevations, you need to use Labels and make the Labels display the desired information in the desired format.
Select the Doors/Windows, and use the "Document > Annotation > Label Selected Elements" menu command to do it.
It is also possible to save your own Labels, if the ones available by default do not meet your needs.
