2019-07-17 12:42 PM
2019-07-17 02:33 PM
2019-07-20 10:36 AM
2019-07-20 01:49 PM
famadorian wrote:Create two Views, one for each rotate angle (use the Get Current Window's Settings in the View Settings dialog box). Then use the Views to switch orientations.
You mean I have to manually rotate the view every time I want to view the project with correct north?
There's no way to switch easily between project orientation and correct north?
2019-07-21 08:05 PM
David wrote:Absolutly !
Create two Views
