We value your input!
View during editing
Erich
I think that this is a behavior change with 18 (or at least versions since 16) but I want to make sure I am not missing a setting.
In AC 16, if I went to edit an element that had a cover fill and a solid background pen, and that element covered over another element or object, say rafters. Then when zooming in or out, the outline of the elements or object below because temporarily visible allowing one to quickly check on their location and making it easier for selection and modification.
Now in AC 18 elements covering other elements or objects remain solid and do not allow a view below while zooming.
Is there a setting anywhere to change this back to the AC 16 methodology?
Erich
AC 19 6006 & AC 20
Mac OS 10.11.5
15" Retina MacBook Pro 2.6
27" iMac Retina 5K
6 REPLIES 6
Hi Erich,
I can confirm that there seems to be a bug in 18 that ignores the Work Environment setting which gave that prervious behavior. This might be a Mac-only issue...
I'll ask GS...
One of the forum moderators
AC 28 USA and earlier   •   macOS Sonoma 14.7.1, MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
OK... With "Contours Only" or "Simplified Model" ... I get the old / desired behavior when I zoom in and out with the mouse ... but NOT when I pan... and it used to work with panning as well. Panning simplifies for me in 10, but not 16-18.
See what you see, Erich. And, somebody on Windows want to try this and see if panning always shows the full detailed model (all skins of composites and cover fills) like I'm seeing on OS X?
Thanks.
Erich
Karl,
Thanks, that was my issue. I thought I had captured all the settings from my old WE but I missed that one and had it set on Full Model.
As for Panning, it does not work in 16 onward for me either. I do not currently have earlier versions installed and I do not remember the older behavior.
Erich
AC 19 6006 & AC 20
Mac OS 10.11.5
27" iMac Retina 5K
Must be a Mac only issue.
All fills disappear when panning and zooming for me in 'Contours Only' or 'Simplified model'.
Tested 17 & 18.
Thanks, Barry. That helps to narrow it down to just panning on Macs...which makes it seem like a bug, or at least maybe an oversight. Will report...
Csaba Kezer
Hey All,
We have checked this and can confirm that it doesn't work on mac as it supposed to be. Indeed on windows it is fine. We have added this to our database and will correct it.
Thanks for reporting,
Csaba
Csaba Kézér
Director, Global Customer Support
