Showing results forΒ
Search instead forΒ
Did you mean:Β
Search instead forΒ
Did you mean:Β
View of Reference Lines only. Is it possible?
Hi.
I would like to setup a set of Views aiming to help the setting-out in constructions fields of reference meassurements.
Is it possible?
In Graphic Overrides I am not able to override Reference Lines Type.
3 Replies 3
Steve Jepson
Yes. If I understand the question. There is probably more than one way to do what you need. You can make a wall that will display only a line where the reference line is if that is what you need. And you can make that line any type you want.
https://www.screencast.com/t/aaYIbwpCnI
What your asking about might be the typical 2-line walls of a plan that shows only the core/framing with dimensions only to one edge of the core.
This is a common way to show Floor Plans that the Framer likes to use because it does not show any of the other wall skins that he does not care about. Is that what you need?
If you can show a picture of what you want it to look like I am sure it can be done with ArchiCAD, no matter what it is.
Aaron Bourgoin
I'd like to print a plan with core wall outlines and the Reference Lines with a linetype assignable to the Reference Line. Don't think that's possible.
Think Like a Spec Writer
MacBook M4Pro - 24Gb RAM
AC4.55 through 29 / AC29.1.0 USA
Rhino 8.30 Mac
MacOS Tahoe 26.4.1
Agree with Aaron.
@Steve, your solution is not printable.
It is only showable in screen.
I want this reference-line highlighting to become printable and customizable.
