Viewing stairs
First post so be gentle with me
I have a set of stairs that starts at GF(0) and finishes at SF(2), when i view my stairs in floor plan for instance gf-floor plan the stairs are not visible, it only shows the railings. The stairs view as they should on the linked level SF2, i have all relevant storeys selected in floor plan display options. Am i missing something?
OK.
I have moved your post as it is a specific question/problem rather than a general Archicad discussion.
Please read the headings to determine the best location to post.
I am sure it is just the floor plan display settings.
Check that the stairs home storey is on the ground floor.
It should be set to display on all relevant floors as you seem to have done.
Then check the 'Layout On' settings - this will affect what can be seen on each storey.
OK.
Thanks Barry
I had start with tread selected rather than riser, the stairs was hovering about 5mm above the slab so it couldn't visualise it in the floor plan. Thanks for your help i just made noob mistake..
