2012-05-04 07:29 PM - last edited on 2023-05-24 12:57 PM by Rubia Torres
2012-05-05 03:39 AM
2012-05-05 04:28 AM
Barry wrote:
I can't see the attached image - although it says it has been viewed 41 times?
2012-05-05 04:12 PM
2012-05-05 05:46 PM
2012-05-05 08:38 PM
David wrote:Loaded all the libraries I could find, no, still won't work. Are there any code writers out there that can helpl. It works on the end wall w/o any openings, but not on the wall that has an empty opening over a 4' barn door. Perhaps having two openings in the same place is the problem, but don't know how to show them on elevations unless they are modeled this way...any suggestions?
Archimamamia:
I took a look at the macro LumberComponents_11.gsm and found the call for Database_set "AC_10_INT". I cannot easily figure out under what circumstances this database is called (something to do with wood_pack and pack_type). I also don't know where the Database_set "AC_10_INT" should be found. The "10" in the name probably refers to AC 10, so you could try loading the AC Libraries and see if that fixes the issue. This is really a case where someone who wrote or understands the code could sort this out, but is otherwise too complex.
David
