ā2007-07-02 08:10 PM
ā2007-07-21 08:24 PM
ā2007-07-22 07:18 AM
ā2007-07-22 07:19 AM
ā2007-07-23 02:25 PM
Geoff wrote:Geoff, please make sure you switch off all unnecessary panels from Grid Tool info box. (Currently there was no way to remove them from the Work Environment and sometimes the pre-set visibility screws up after new and reset).
See also how Show on Story does not agree between the settings dialog and the info box.The plot thickens...
ā2007-07-23 02:48 PM
Geoff wrote:Just to make sure we are on the same page:
1. If I set the Grid Element Settings S/E panel from General to Custom I can't get it to switch back, and the numbers don't agree between plan and section (screen shots 1-3).
Geoff wrote:Please send me a PLN, where you have this problem.
2. The bottom marker offset value doesn't always work. In the screen shot it's set to -1000mm but the offset is -500mm (screen shot 4).
Geoff wrote:This is a big problem. Working on it.
3. Associated dimensions other than those placed by the grid tool (such as the one in screen shot 4) are lost on rebuild. Static dimens are OK.
Geoff wrote:Confirmed.
4. Other rebuild issues:
a) A section rebuild (or rebuild and regenerate) won't show changes to the section settings grid tool panel like Show Grid Elements or Dimension lines. You must close and reopen the section window.
Geoff wrote:Either my computer is way too fast or something else, but can't reproduce this.
b) Canceling the Grid Element Setting dialog in section cause any selected grid elements to rebuild.
Geoff wrote:A critique wrapped in a compliment. Thanks
This is a very useful tool and seems to be free of any killer bugs, but it still has a ways to go to reach an acceptable level of performance and ease of use.
ā2007-07-24 06:16 AM
gkovacsp wrote:I had noticed that the panels didn't really fit the tool. I have updated my Info Box per the wiki. This does reconcile all the differences between info box and settings dialog box, thanks.
gkovacsp wrote:But what if I want to revert a section from Custom to General. Can't seem to do that.
If someone wants to change the Grid Element's appearance on one of the sections, but wants to leave all the others untouched, then he can do the following...From now on on that section the Grid Element will use this custom Section settings.
This is a big problem. Working on it.Glad to hear it. Here are a couple more:
Either my computer is way too fast or something else, but can't reproduce this.Lucky you
ā2007-07-24 04:23 PM
ā2007-07-24 08:11 PM
ā2007-07-25 12:45 AM
Geoff wrote:This is why I had created my own object (which I can no longer use).
Since this tool is in a rapid state of development (I hope) I will keep the ball rolling by suggesting some modest improvements:
1. More marker head options. They don't need to be custom, just a selection of regular polygons: round, triangle, square, hexagon, octagon.
2. Option for mask fill of marker head (all markers should include this, always).
ā2007-07-25 03:36 AM
gkovacsp wrote:well i thought i'd give you the benefit of the doubt and try the new improved AC11 grid tool . . .
Geoff, thanks for all the feedback, I added all of them to our bug tracking system.
