matthewjj
WHEN IS GRID TOOL COMING???
Can anybody shed light on when the AC 11 grid tool will be available!!!
My team beta tested AC 11 and throughout the beta test the grid tool was available, albeit just as flawed as it was in 10. Then suddenly the tool was taken away from us when the final release came out. We were urged to used AC 11 on 'real' projects by graphisoft and so we did. We have real clients and we are working on a real $100m hotel and we need our grid tool back, asap.
*We have tried loading the RC1 grid tool but it doesn't get read by the final release.
matt johnson
archicad since 2004
imac 27, 4.2 GHz Intel i7, 16 GB RAM, radeon 575 4 GB, macOS 10.14.6
imac, 4.0ghz i7, 16gb ram, Radeon M9 390 2GB, OS X El Capitan
86 Replies 86
Laura Yanoviak
~/archiben wrote:
• i can't get them to 'show on all stories'. this was part of my default settings: it was ignored. selecting them and switching from 'home storey only' to 'all stories' has no effect.
I consistantly had this problem in AC10.
SeaGeoff
Ace
I was going to test Ben's bugs (say that 3 times fast), but am now experiencing a reproducible crash whenever I attempt to edit an existing grid system with the Grid System command. Unfortunately I must conclude that this tool is not ready and should be avoided until it is updated and can be tested again.
Regards, Geoff Briggs
I & I Design, Seattle, USA
AC7-29, M1 Mac, OS Tahoe
Graphisoft Insider's Panel, Beta Tester
Rod Jurich
Geoff wrote:
/..... I must conclude that this tool is not ready and should be avoided until it is updated and can be tested again.
Many thanks for your efforts "beta boy"
One more 80%er
And so it goes.
Rod Jurich
AC4.55 - AC14 INT (4204) |  | OBJECTiVE |
Laura Yanoviak
It looks like I won't be able to migrate until this is fixed, so I sincerely hope it is SOON.
Paul King
Mentor
That announcement is a bit rich!
Yes with hotfix 1040 for AC11 Grid Tool now included again with Goodies - but of course it no longer works usefully at all by default
Once placed, you can no longer edit the parameters of a grid object in any way in plan or elevation or section - unless by some arcane chance you happen to know that you need to manually enable normal functionality in a workspace sub menu (why on earth would anyone want it switched off ?)
Tool is worse than useless unless you know this trick, and default is bordering on insulting in fact (as if we are not to be trusted with the ability to edit scary technical things like grids)
PAUL KING | https://www.prime.net.nz
ArchiCAD 8-29 | Twinmotion 2025
Windoze 11 PC | Intel Core Ultra 9 285K | Nvidia Gforce RTX 5090 | 64 GB | 2x4K monitor extended desktop
BUMP!
Any updates related to this tool.
Thanks,
rmg7
TomWaltz
rmg7 wrote:
BUMP!
Thanks,
rmg7
well, it's a goodie you can download and it's usually got some bug fix or another in each service pack.
Tom Waltz
