DataChris wrote:
@LaszloNagy... Using the current version. That screenshot was from the current help center documentation. I have a million wishes for the app. Don't want to take over the board with all of them 😉
Feel free to post your many wishes / questions. That is what this forum is for... BUT, when you do, please do as you did with this thread (thank you): start a separate thread for each unique question/wish with a subject line that summarizes the question/wish ... AND post it in the appropriate sub-forum.
As to the non-docking palettes, my best guess is that some of these don't dock simply because of legacy code and limited resources to rewrite the code. Remember that ARCHICAD is 30 years old and management must juggle updating old code with adding new features. Most often in recent years, the old code that has seemed to be updated (from this user's perspective) is that which can be multi-threaded and which has allowed ARCHICAD to run faster on multicore processors. The palettes you mention existed before docking palettes were introduced. Element Info was rewritten for 21; perhaps some of these others will be in future versions.
Personally, I've not had any concern with Solid Element Op, Find & Select, etc being not docked. cmd-F/ctrl-F brings the Find & Select palette up at any time - and it remembers the last place you had it, so it can certainly be pushed adjacent to the docked palettes if you want. I, too, use Solid Element Ops enough that I want ready access to it - so I just define a keyboard shortcut for it in the Work Environment. I've been using shift-O (mneumonic for me for S-olid element O-operation), but just define something that makes sense for you.
One of the forum moderators
AC 28 USA and earlier • macOS Sonoma 14.7.1, MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
