2021-05-07
07:15 AM
2023-05-09
03:43 PM
Rubia Torres
2021-05-07 10:27 AM
2021-05-07 02:33 PM
Podolsky wrote:Thanks, Podolsky ! I did it using the wall "complex profile" from ARCHICAD. I already tried the shell tool. May be I have to combine it with the curtain wall to obtain the expected results.
Curtain wall in ArchiCAD does not support double curvature surfaces. It can be only flat or cylindrical. For shapes as you are showing was designed tool called Shell. After you model the main shape, you can create mullions. I guess easiest way is to use Morph tool, or convert element, made with Morph as GDL object.
2021-05-07 03:51 PM
2021-05-07 04:52 PM
Podolsky wrote:
The plus of shell is that you can extrude or rotate it anyway you want and also have any contour on the plan. Shell was especially designed for complex shape roofs (as in your case).
