Wall Accessories - Mouldings & Panels
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2005-05-19 02:23 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2005-05-19 03:33 AM
just a guess i'm afraid . . .
~/archiben
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2005-05-19 10:48 AM
Is it possible that you have carried out a SOE on your walls and the roof?
If so you may need to do some fine tuning of your model to get it to work correctly.
Like ben I'm just guessing here.
Cheers.
Ben
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2005-05-19 12:49 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2005-05-19 03:33 PM
It seems that the guilty is the top cornice. See attached image.
I did not check for the slab tool accessory.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2005-05-19 10:23 PM
Thanks Olivier for the great explaination of the "bug".
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2005-05-20 10:49 PM
-- Matthew Peychich
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2005-05-21 02:00 AM
I am using the material number 1 for my "Base" / Siding. I changed the value in the third column from 1/2" to 3". Was this not enough...?
The Screen shot shows the extended portion still...
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2005-05-21 02:33 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2005-05-21 04:53 AM
To rectify the bug, open the obj. in Lib Parts editor, go to 3D Scripts and look for script under "Cutting Bodies", increase the values of Reference Thickness by 0.5 (enough to cut out the remainding portions):
!! Cutting Bodies !!! Cutting Bodies !!! Cutting Bodies !!
group "cutting body"
dim cut_set[5]
cut_set[1]=0 ! Lower Cut
cut_set[2]=0 ! Upper Cut
cut_set[3]=1 ! End Cuts
cut_set[4]=1 ! Window/Door
cut_set[5]=1 ! Conecting Walls
call "Wall Cutting Body" parameters ref_thickness=ref_thickness+0.5, gs_mat=gs_mat, cut_set=cut_set,
ac_accessory_debug=ac_accessory_debug, gs_gdl_debug=gs_gdl_debug,
ac_wall_height=ac_wall_height, ac_wall_radius=ac_wall_radius, ac_wall_length=ac_wall_length,
ac_wall_resol=ac_wall_resol, ac_refside=ac_refside, ac_angles=ac_angles, ac_side_poly=ac_side_poly,
ac_top_poly=ac_top_poly, ac_bot_poly=ac_bot_poly,
ac_wd_poly=ac_wd_poly, ac_curved_wall=ac_curved_wall, ac_cont_pen=ac_cont_pen,
bot_ext=bot_ext, top_ext=top_ext
endgroup
Save the object and you are ready to rock!
Win 10, Archicad 19 INT
