Wall Constraints
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2017-12-16
07:32 PM
- last edited on
‎2023-05-24
08:25 AM
by
Rubia Torres
‎2017-12-16
07:32 PM
6 REPLIES 6
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2017-12-17 06:39 PM
‎2017-12-17
06:39 PM
No, you have to model them correctly in the first place. Be sure to use the shift key or a guideline to constrain - not simply clicking in space or assuming that a convenient snap point will result in a perfectly orthogonal wall.
AC 28 USA and earlier • macOS Sequoia 15.4, MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2017-12-17 07:31 PM
‎2017-12-17
07:31 PM
There was a long discussion concerning this some time back. May be helpful.
http://archicad-talk.graphisoft.com/viewtopic.php?t=53498&start=20&postdays=0&postorder=asc&highligh...
Ted Taylor
Atlanta, GA , USA
iMac (Retina 5K, 27", Late 2015)
3.3 GHz Intel Core i5 32GB
AMD Radeon R9 M395 2GB
OS10.14.2,
Latest Archicad 22
Atlanta, GA , USA
OS10.14.2,
Latest Archicad 22
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2017-12-17 09:01 PM
‎2017-12-17
09:01 PM
Archicad Guru Link commented on a solution HERE and loaded an object to the Object Depository HERE which will check walls for orthogonal-ness. Maybe give it a go. It will at least find any other walls which may be out of square, which could be part of the problem.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2018-01-04 10:23 PM
‎2018-01-04
10:23 PM
That label is fantastic for QA! Thanks for linking it
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2018-01-04 10:28 PM
‎2018-01-04
10:28 PM
Thanks but it was James Murray who coded it! I just had the idea.
Link.
Link.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2018-01-04 10:30 PM
‎2018-01-04
10:30 PM
Many thanks to James also then!!
Link wrote:
Thanks but it was James Murray who coded it! I just had the idea.![]()
Link.
