Wall End tool and Profile Based Walls !
Ghassan Kanaan
I found that the Wall End Tool doesn't work for Profile Based Walls.
Is there a way to overcome that with other methods ?
Thank you
Hello Ghassan Kanaan,
If you appreciate Profile Based Walls why don't you use Profile Column by the same way to modelise wall end ?
Christophe - FRANCE
Archicad Designer and Teacher
Archicad 15 to 28 FRA FULL
Christophe - FRANCE
Ghassan Kanaan
Thank you Christophe Fourtineau, I will try this ( Merci )
