Wall Fills match wall orientation not project orientation
Gus
Using fills one can orient the fill to the project or to some other direction. Is there a way to do the same thing with a wall fill so that the fill orients to the direction the wall is oriented rather than to the generic project orientation. It always looks weird when an agacent perpendicular wall does not have the same fill as the wall next to it because it has a different orientation than the wall next to it.
www.michaelgustavson.com Architect NY WI IL
Madison WI
Archicad21 MEP EcoDesSTAR Win10-64-bit
EliteBook8570W Corei7-3630QM@2.40GHz
QuadroK2000m RAM32 (2)250GBSSDs
4 Monitors Internet:4Up60Down
2 REPLIES 2
Set up a Composite using the fill you want. You can specify how it aligns fills - to Project Origin or Element Origin.
Finally found this feature in 17, it has been relocated to the Building Materials...
