Wall Intersection Problem
Is there a way to get rid of the bug that creates this small line? And why does it appear anyway?
This is a problem I've had for ages...
10 Replies 10
As Ben mentioned, it is to do with the way AC processes wall cleanup. Based (amongst other things?) on the relative thickness of the walls.
We have found that 'cycling through' pairs of intersecting walls normally (on the second or third 'intersect') gets them to clean up ok.
It might be useful to assign 'intersect' to ctrl-Q or somesuch to make it easier to use...
HTH - Stuart
