Wall connections
I am drawing a plan out, and normally when i join the wall the connection lines disappear. Today they are all choppy and not connecting at all. Any ideas?
5 Replies 5
Is clean wall intersections turned off by chance? check this under the options menu.
cheers,
dan
I checked and that didn't seem to change my connections. I drew the walls with markerfill. Could that have had something to do with it?
Also, when I place in doors, it's not recognizing that other walls are drawn. It's like each wall is a completely separate piece from the next.
Erika Epstein
Check your display options.
If this doesn't resolve the problem, post a screenshot.
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
Djordje
Did you try in 3D?
Are your walls done with the wall tool or did you draw the fills?
Please clarify.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
