2014-02-16 10:56 PM - last edited on 2023-05-24 09:04 AM by Rubia Torres
2014-02-17 02:46 AM
2014-02-17 02:58 AM
2014-02-17 03:15 AM
youngdoooooo wrote:I don't know what window object you are using but the default trim thicknes is probably fine if you are using a standard composite wall with no wall accessory cladings.
Oh ok. So it was just the matter of thickness. I put it as 55mm and it's finally showing on the elevation. Is there a standard thickness for it?
Cheers
2014-02-17 04:04 AM
