Wall fill suddenly not showing on floor plan
I started a new project as normal, added a map (jpg) and resized it. Started drawing above the map. When I start project I like my cut fill on the walls to be black, foreground fill, but in this project the walls are only showing as lines (inner and outer), no matter what I do. I´ve tried change the cut fill into all of the options, still the cut fill ain´t showing on my plans, neither on 1st floor or 2nd floor.
I´ve also filled the slab with concrete fill, but it is only showing white..
What has gone wrong? Any ideas on how to make it show cut fill again? The plans become much more to the point when I´m able to fill the walls, so please help me!
4 Replies 4
In my sections there is neither showing any cut fill, just the uncut fill (white, since the material i use is paint 01 (norwegian "maling 01")
Ok, I finally found out, it was as simple as the mode of the model view.
thank you for your time, it is good to have a forum to talk to, even if it is a monologue! kind of two way monologue.
vmasalias
Hi! I am having the same problem! Could you explain where you found the mistake ?
Try choosing a different Graphic Override.
You probably have one active with a rule making the fills transparent.
