Wall height
Greetings all,
I am learning ArchiCAD V9 and will be greatful indeed if someone could help me with a bit of information.
I have drawn in the walls for a house and set the wall height at 2700 mm. However when i view the drawing in the 3D window the wall appears to have no height at all. ( sorry about the dumb question and i am using the tutorial but can't seem to put that right )
Attached is a screen grab of the drawing in the 3D window.
Kindest thanks for any help..
Regards
John Venediger
My apologies .. this thread should have been in the new users forum
4 REPLIES 4
Aussie John
Let's see the wall settings window. More likely to give us some clues
Cheers John
[/size]
__archiben
in addition to seeing the wall settings dialogue (with one of your walls selected), i'd like to know just how big the slab is . . . if all of your walls are indeed 2700 high, i would suspect that the slab is at fault: i.e. drawn absolutely massive, possibly by a factor of 10?!
HTH
~/archiben
b e n f r o s t
Many thanks Ben and John ,
not to sure what I did but the walls are now visible , this happen when I zoomed in and out with the editing motion / turn tool , I must be clicking the wrong buttons somewhere …
The size of the slab is 26000 x 13000 x 100 mm , all walls were set to a height of 2700 mm
Kind regards
John
Aussie John
all's well that ends well
Cheers John
[/size]
