2006-10-05 09:11 PM - last edited on 2023-05-25 06:17 PM by Rubia Torres
2006-10-06 12:08 AM
2006-10-06 12:50 AM
2006-10-06 01:20 AM
2006-10-06 08:18 PM
Link wrote:can’t really say I understand all these profile design layers yet, but changing them didn’t seem to make a difference, I’ll go through the help to read about these later..
Have you tried making your Opening Reference Lines visible? I see (by the tick) you have activated them, but have you moved them to the correct edges of the profile?
2006-10-07 06:05 AM
Hassanen wrote:Wall accessories?
So what methods do you guys use to create a wall with different exterior materials, like the image for example, a brick wall with stone base and pre-cast horizontal strips? So that when you place a window in it the materials wrap around correctly, the only method I’ve used in the past was a complicated combination of different walls and slabs and empty openings! I was hoping I don’t have to do that again.
2006-10-07 07:48 AM
2006-10-09 08:58 AM
Hassanen wrote:Sorry Hassanen, this is not the solution you need. In fact I don't think there is a solution to your problem.Link wrote:can’t really say I understand all these profile design layers yet, but changing them didn’t seem to make a difference, I’ll go through the help to read about these later..
2006-10-26 09:06 PM
2006-10-27 12:58 AM
