Wall showing incorrectly in plan view Archicad 18 Solo
Michael Reed
Hi, Can anyone tell me what I am missing with the window settings in plan view. The lines by the cill and board are showing incorrectly the thick black line .35 has become a thin line .13.
I have altered just about very option and cannot correct it.
Mike
ArchiCAD 21 Solo, iMac 2.93GHz Intel Core i7 8GB OSX }
Katalin Borszeki
Hi, this could come up if the floor plan display is set to "projected" or "projected with overhead". The fills cover up the contours of the wall. Please try setting it to "symbolic". Thanks
Katalin Borszeki
Implementation Specialist
GRAPHISOFT
Michael Reed
Hi Katalin. I tried that but it only then showed the basic symbol - no detail which I needed. I have since explored the MVO set up, and that seems to have solved it. I can only ascertain that when upgrading from 17 to 18 the MVO settings were changed. I am now able to use MVO as the criteria on the object. Hope this makes sense. Thanks for your input. Mike
