Wall top height link
When I change the top height of a wall to Not Linked with a custom height, its not possible to relink it to a story level again, is there any solution that i'm not aware of?
10 Replies 10
Minh Nguyen
Graphisoft Alumni
Graphisoft Alumni
Sabzbon wrote:
I tested that in default template and same happend but I found the problem, if you change the height, befor you do the relink you have to manually set the story height then link the wall. if the height is anything other than story height, it wont relink
Thank you very much for your report!
Could you help us to investigate the issue by making a short video of the issue? I tried to replicate it from your description, but unfortunately the Top linked worked even with a custom height wall (tested on Archicad 25 3002).
Thank you for your help in advance, and I look forward to hearing from you!
Best regards,
Minh
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
