Wall under stair not displaying correctly
New Archicad user struggling with various idiosyncrasies. I have a wall under a stair which I cut using Solid Element Operations. Worked fine as the image shows. In plan view, the wall is showing through the stairs. I just can't figure this out.
KrisM
3 REPLIES 3
alemanda
Solid Element Ooerations are not considered in the floor plan representation. If you want a correct representation you should do split the wall into two walls, one is the wall underneath the stair before the cut line and it has to be put on a hidden layer, the other wall which is over the cut line of the stair should be put on a visible layer.
eng. Alessandro Mandala - Italy
AC27 latest hotfix
Win 10 Pro 64bit
Double XEON 14 CORES (tot 28 physical cores) - 32GB RAM - SSD 256GB - Nvidia Quadro K620
Display DELL 2560x1440
That is disappointing but I will implement your solution. Thanks.
David Maudlin
KrisM:
You can use the Display Order to Bring the Stair Forward of the Wall, and set the Fill of the Hidden Part to be transparent.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
AC29 USA Perpetual • Mac mini M4 Pro OSX15 | 64 gb ram • MacBook Pro M3 Pro | 36 gb ram OSX14
