Dave Jochum
Walls Not Wrapping Columns
I'm having trouble understanding when walls will wrap columns and when they will not. I've placed a column "by the book", i.e., composite wall w/ wrapping skins, chose wrapping before placing column, column touches wall core. While I can get many instances to work, others will not. Without going into more detail, is there something I should be taking into consideration that I haven't mentioned?
Dave Jochum
J o c h u m A R C H I T E C T S http://www.jochumarchitects.com
MBP 16" (M1 Max) 64 GB•OS 15.6.1•AC 29 Silicon (latest build)
10 Replies 10
Dave Jochum
Alex wrote:
I do know that layer intersection numbers can affect how a column merges with a wall. Keep that in mind. If they have different layer intersection numbers they won't merge.
Alex--That's it! Thank you. It's usually some dumb little thing I overlook. It should have been obvious. Anyway, good job, as usual.
Thanks also Miquel for responding.
Dave Jochum
