Eman
Walls & Slabs question
If I put a slab in Story 1 with reference line top, the walls of ground floor appears. I mean when the walls of ground floor and the slab of story 1 are exactly same height and altitude.
I want that the walls do not appear.
Eman / Draftsman
Works at an Architects Company using ArchiCad 21
Intel(R) Core(TM) i5-6500 CPU @ 3.20GHz 3.19 GHz, 8.00 GB, 64-bit operating system, x64-based processor
1 Solution
Guru
My first thought would be to check your Building Materials. My guess is that the Building Material of your wall has a HIGHER Intersection Priority than that of your slab, hence it is trimming your slab which will show up on Story 1 even when the walls themselves are not set to show above.
Options => Element Attributes => Building Materials => [Desired Building Material] => Intersection Priority
Ling.
Go to post
2 Replies 2
Guru
Ling.
Eman
Hi Lingwisyer and thanks for your reply. Yes that was the problem, now it is OK!
Eman / Draftsman
