an hour ago
Several walls are present in the plans and I can see them in cross sections but they disappear in interior elevations. I keep the same layer combinations and the same characteristics for visibility but if they are frontal they disappear letting visible the other walls behind. The behavior seem random. In some interior elavation there is no problem, in others this problem appears. I cannot work with the interior elevations because of this randomness.
I checked the walls, they are not dubbled.
I think this is a bug.
Could you confirm ?
an hour ago
I found it out : Exclude blocking walls - what's the depth of this and where can it be changed ?
an hour ago
In the elevation settings, has the 'Exclude View Blocking Walls' option been ticked by any chance?
an hour ago
SNAP!! 🤣
