ā2019-11-27 11:24 AM
ā2020-02-11 01:12 PM
Moonlight wrote:
As an old ArchiCAD user, I have found out that Graphisoft is not that type of company that will do what ever that is asked for to do, but will give you the answer you need, but lately I'm starting to have my doubts.
ā2020-02-11 02:23 PM
ā2020-02-11 03:05 PM
Moonlight wrote:
@BRICKLYNE CLARENCE
I see that I wasn't clear in my previous explanations.
2. About Graphical GDL & "reinventing the wheel":
2.01. Many of you may not know that GDL is capped in what is refereed to bi-directional communication data exchange (i.e: the data that is sent/received between library parts and the program is limited), when right now, our practices are in the verge to conversion to adopt IT technologies and data, which is something that is somehow is already/almost solve/WIP solved with Grasshopper... so creating a Graphical GDL will not solve the problem of increasing ArchiCAD's user base........
ā2020-02-11 03:08 PM
Moonlight wrote:
@BRICKLYNE CLARENCE
Few years ago, in ArchiCAD EspaƱa FB group, a member asked how to do something (I don't remember what was it exactly), so many proposed many different ways, and I proposed to use Grasshopper to do simple operation, since it was going to be quiet quick to preform, and I would stay online to give that member the indications to create the algorithm step by step in case he didn't knew how to use Grasshopper.
Then a member started to laugh and to joke to undermine the idea of using Grasshopper, long story short, he said, I don't want to program, nor to learn programming, I want something that does what I want when I want to it to be done how I want it to be done.
And as far I know and seen, most ArchiCAD users are like that whether it was for Grasshopper or GDL, except for a minority and those who are really busy and don't have some free time to dedicate it to learning.
ā2020-02-11 03:10 PM
ā2020-02-11 04:24 PM
ā2020-02-11 04:34 PM
ā2020-02-11 07:07 PM
DGSketcher wrote:Exactly. We are missing the target focusing in a Graphical/Visual GDL interface. What architects want, is to create parametric "Things/Forms/Buildings" inside Archicad using all AC Tools (Walls, Slabs, Roofs, Objects, etc..) .
I will say all the talk of visual GDL has me amused because the only reason I see a need for it is because to date Graphisoft have failed to provide the ability to create blocks/modules that can be simply modified within the main drawing using standard tools.
As Bricklyne Clarence well mentioned, a good start has been made by Graphisoft with the Offset Modifiers inside the Custom Profile Editor. Extending this capability to the 2d/3d environments should do the trick without having to create a new App. Lets see if it will evolve, because right now it is only scratching the surface.
ā2020-02-11 07:11 PM
ā2020-02-11 07:36 PM
