‎2018-06-14
07:41 PM
‎2023-05-24
08:21 AM
Rubia Torres
Solved! Go to Solution.
‎2018-06-15 04:24 AM
4hotshoes wrote:Hi Todd. This is what Partial Structure Display (PSD) is for. You tag the drywall and hardwood layers of the composite as "finishes", tag the joists and subfloor as the structural 'core' - and then save the desired PSD setting - entire, without finishes, core only - with the view to see what you want.
I know I can build a composite floor with all of the material layers (Drywall ceiling below, Joist, OSB sub-floor, hardwood finish). However, for construction drawing dimensions, I don't need the Drywall or hardwood layers when figuring structure: bearing heights or floor to floor heights ...
‎2018-06-15 02:00 AM
‎2018-06-15 11:12 PM
