We value your input!
What is the x coordinate on the left?
LeeJaeYoung
If you look at it, it will be there, but if you click on it, it will disappear and then reappear.
What is this?
I would appreciate it if you could tell me how to turn this off.
Today is Chuseok in Korea. It is also called Hangawi in pure Korean.
Good luck to everyone. ^^
AC27 on window 11
Do you mean the Project Origin in plan (also in sections and elevations)?
4 REPLIES 4
LeeJaeYoung
Appears in floor plan.
AC27 on window 11
LeeJaeYoung
Origins (graphisoft.com)
AC27 on window 11
LeeJaeYoung
thank you I couldn't find it because I didn't know the name exactly... but I found it in the help file and understood it.
Thank you again today.
AC27 on window 11
