‎2008-05-14 01:26 AM
‎2008-05-14 03:17 AM
‎2008-05-14 03:37 AM
‎2008-05-14 03:54 AM
Richard wrote:i, too, make the storey height the top of the STRUCTURAL slab, but i model my floor finishes as totally separate elements on a "finishes" layer on top of the structural floor slab.
I personally like to set it at the top of structural floor, and make sure that the floor is drawn as a composite slab,...
‎2008-05-14 04:14 AM
~/archiben wrote:Well, in my case the top of the structural slab is what will vary. The radiant heating system we'll be using is one by Warmboard which inlays the heating elements (pipes/hoses) into a 1 1/8" floor sheathing slab. It is approved for residential use in place of 3/4" structural floor sheathing. So it would seem the finish materials would be a separate issue.
i too make the storey height the top of the STRUCTURAL slab, but i model my floor finishes as totally separate elements on a "finishes" layer.
this give me greater visibility control ('core only' for the GAs) and allows different floor finish materials to be used over one floor area, or even within one room.
shims aside, it sounds like this would suit you atlantex?
~/archiben
