archislave
Which Builds for Leopard?
I currently have v11 970 running very stable. If I upgrade to Leopard will it still work?
Archislave
archicad 26.0 US, M2 Macbook Air
5 Replies 5
TomWaltz
Build 1210 would run a lot better, on Tiger or Leopard. The key is your individual machine. What works for 10,000 other people may break on yours.
Tom Waltz
archislave wrote:
I currently have v11 970 running very stable...
And, yet so many bug fixes have been made between build 970 and the current 1210.
Check out the signatures of various people here and you'll see lots of us running 1210 and Leopard. Consider that Leopard was not even released when build 970 was. 😉
Karl
archislave
I a little confused...
970 never worked for leopard.
What about 1040?
I assume 1200 and above works well?
Archislave
Well, i use AC11 on leopard since 1040 build, and all ok
When I upgraded my G5 to Leopard, everything (including ArchiCAD,) slowed. Increased RAM helped a lot, but the main thing I took away from the upgrade was the knowledge that Intel Macs were the best solution.
Rex Maximilian, Honolulu, USA - www.rexmaximilian.com
ArchiCAD 28/29 (user since 3.4, 1991)
16" MacBook Pro; M4 Max (2024), 48GB RAM, 1 TB SSD, 32-Core GPU
Apple Vision Pro w/ BIMx
Creator of the Maximilian ArchiCAD Template System
