ā2009-12-01 11:21 PM
ā2009-12-01 11:46 PM
ā2009-12-02 03:28 PM
Peter wrote:Hi Peter,
Hi 'N',
Use normal walls for the side walls. Put an angled curtain wall at the front. In the 'Design'>'Modify Curtainwall' menu you can connect the two walls either side which will make them automatically slope with the CW. An alternative to this would be to place a normal sloped wall inbetween the two side walls and place standard windows into it. You may have to do this with the rear wall anyway if it's solid.
Use a sloped roof for the roof and either use the trim-to-roof function, or SEO to trim the top of the walls away.
That should get you started!
ā2009-12-02 03:52 PM
ā2009-12-02 04:03 PM
ā2009-12-08 05:44 AM
