SOLVED!
White fills show up grey
I'm not sure what exactly has happened here. I'm pretty sure I didn't do anything, but I must have done something.changed some setting by mistake, because all of my white pens show up grey. I'm using Archicad 12, Student Education version on Windows XP. I've attached a screen shot. As you can see my pen set says the fill is white, but like the brick workabove, the highlighted concrete fill is showing up with a grey background. Anyone know whats happened here?
11 REPLIES 11
Josh Verran
Just had the same issue occur, had me stumped.
I have a suspicion that the cause of the issue was me opening a DWG through the File > Open menu.
There was a dialogue that came up which I rushed through "OKing", perhaps there was something there that caused the Work environment to change.
GRAPHISOFT Certified BIM Manager | Senior BIM Specialist | LinkedIn
ARCHICAD 18-28 | BIMcloud | CI Tools | Grasshopper - Rhino | CloudCompare | Bluebeam
Australia & New Zealand
Windows 11 Business | Intel Core i9-13950HX @2.2GHZ | 64Gb RAM | 2x Samsung S27F350 1920x1080 60Hz | Nvidia RTX 4000 Ada Generation Laptop GPU (12Gb)
No, I don't think so.
You can only change Work Environment settings by going into the WE and changing them yourself, or applying a different WE.
I think the default WEs have this option to automatically adjust pen colour set as active.
