Gus
Why a navigator if Organizer does the same thing?
Is there something that the "Navigator-Project Map" does that the Organizer doesn't do? Is the "Navigator-Project Map" redundant?
www.michaelgustavson.com Architect NY WI IL
Madison WI
Archicad21 MEP EcoDesSTAR Win10-64-bit
EliteBook8570W Corei7-3630QM@2.40GHz
QuadroK2000m RAM32 (2)250GBSSDs
4 Monitors Internet:4Up60Down
2 Replies 2
Organizer does much more, in a multi-pane view. Yet, the nav/proj map provides a compact, tabbed interface that docks nicely when in single-monitor mode. With multiple monitors, I usually leave Organizer open on the second monitor. With a single monitor, I only open the floating Organizer when I need it for dragging/dropping items to create or duplicate views, publisher items, etc.
AC 29 USA and earlier   •   hardware key   •   macOS Taho 26.5 MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
Gus
Got it.
I use two monitors. I didn't think about how cumbersome that would be with just one.
Possibly there could be a tab on the Navigator that turned it into the Organizer as needed. Maybe this already exists.
Thanks
Aloha
Madison WI
