Why can't I change the slab thinkness???
I try to draw a 200thk slab, but the slab setting is set by 300 and shadowed. How can I change this figure?
Thanks for help
If it is a composite the thickness is not variable. (check Structure, cut fill parameter). If you want to use a composite with a different thickness, you need to create another one. Use an ordinary fill if you want a variable thickness.
HTH
Thanks alot S2art,
I wonder why the Help content of ArchiCAD doesn't expect and cover such obstacles that may challenge new users.
Cheers
