ā2007-11-14
03:48 PM
ā2023-05-23
05:04 PM
Rubia Torres
ā2007-11-14 04:03 PM
jagostinho wrote:Joaquim:
What are the advantages of importing a DWG file as GDL object into AC?
ā2007-11-15 01:43 AM
ā2007-11-15 02:32 AM
ā2007-11-15 10:14 AM
ā2007-11-16 09:47 PM
ā2007-11-17 11:50 AM
ā2007-11-17 01:39 PM
ā2007-11-17 02:02 PM
ā2007-11-17 03:48 PM
Bringing in Autocad files like you describe is easy but might create problems with layers etc. Your layer list will be long, your line type menu will be weird, etc. This is also the case if you Xref it or Merge directly into your current project. (I think just dragging in a dwg block into a floor plan is equal to a Merge)This is a good point Thomas. In this particular case though all of the items were on the same layer when the blocks were written.
Every method has it's pros and cons.
