Wiki help
I've been reading this Wiki:
http://www.archicadwiki.com/TechNotes/Composite%20Walls%20with%20Varying%20Skin%20Heights?highlight=...
and following what it says to do about setting the vertical stretch but my walls still won't change height. Is there something missing from the instructions?
Rick
10 REPLIES 10
Looks OK to me - on quick scan. Note that you cannot shrink a wall shorter than its profile - you can only make it taller by stretching the vertical stretch zone.
AC 29 USA and earlier   ā€¢   hardware key   ā€¢   macOS Taho 26.1 MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
That would be the problem then. I knew that was usually the case but I thought this Wiki article was showing a way around that. Oh well, Trim to Roof still works.
Rick
I guess I can make my walls really short from the get-go.
Rick
Dwight
There's ALWAYS a solution.
Dwight Atkinson
That's pretty much my motto, Dwight. I also believe you can engineer anything to work.
Rick
Rick
Actually, that is what one should do for complex profiles - make the wall as short as it every might be (or some reasonable small unit - such as 1' tall), so that you have the flexibility to make it some arbitrary height.
I've seen a number of people who have created profiles for walls that are 10' tall - kind of eliminates possibilities when done that way.
Dwight
That was also Rube Goldberg's motto.
http://www.break.com/index/best_rube_goldberg_ever.html
Dwight Atkinson
Dwight
And of course, everyone knows that the stretch range can be limited to specific regions of the section?
You move the dotted lines to encapsulate the stretchy area.....
Dwight Atkinson
Wonder how many takes it took to get that all to work. ROFL
Rick
