2007-04-11 03:16 AM
(..) ArchiCAD will not be a fully multi-threaded application at any time soon. This is partly because re-writing the ArchiCAD code to support multi-threading is a huge task, and there are areas where it would not cause a dramatic performance increase. Graphisoft will focus on the areas where multi-threading brings the most benefit.thus you don't need octocore (or even quadro) mac pro "at any time soon", because it's a big job for them. (if i think that ac on 8 cores would use 1/8 of the resources available-
Transferring a 32-bit application to 64-bit requires reprogramming even the most basic functions in the software, therefore the change to 64-bit in business softwares will happen at a much slower pace than the rapid change from 32-bit processors to 64-bit processors in the Personal Computer (PC) industry.so mainly they are basing the answer once again on excuse, that it requres recoding ac + on a bad market practise "aww, the other business software developers are also slow on this". sorry, but that doesn't apply to other apps i use, ie, c4d, maxwell. yes, they are a different profile, but- whatever harware resources i give them- it's been effectivelly used. and that's the reason they REALLY are top software solutions. and the argument that archicad has 100x more lines of code can't be an argument.
2007-04-30 01:27 AM
florian wrote:No, they were "fixing the wing". But at least they fixed it.
Did you ever experience an airline to admit that the departure delay is due to a defective engine that needs replacement??? Yikes!!!
2007-04-30 05:43 AM
2007-04-30 10:44 AM
Miki wrote:I would much rather they fix it than not.
I actually had delay based on some serious (over 7 hours) engine repair. It was transatlantic flight and I was wondering If I should actually get on that plain. But it turned out - everything was OK.
2007-04-30 06:12 PM
florian wrote:I remember GS taking the Hawaii users' group to dinner in the early 90's and getting the same response when we requested the ability to manipulate elements in the S/E and 3D Windows...
I remember that in the early 90's I would pester the Graphisoft people at every annual ACS-fair in Frankfurt, Germany why AC would not have any filter tools. Their response was "Who needs that anyway?"
2008-06-18 12:34 AM
2008-06-18 09:23 PM
krokoO wrote:So with multi-processor support now, will 64-bit be the next step? (AC13)
ac12 and multiprocessor support? the developers are reading this forum actually, aren't they?
2008-06-18 09:46 PM
LINZ wrote:I hope so
2008-06-18 10:10 PM
krokoO wrote:I think AC12 will be able to use my FOUR cores... not just TWO.
Just making a sticky note for those again asking "which from the top workstations would be better?"- the computer to get the maximum out from AC now is first generation CoreDuo (if talking about Intel) processor (it's 32bit, Core2Duo is 64, but you don't need that) and max 4GB RAM. Above that it's still overkill for AC.
2008-06-18 10:27 PM
LINZ wrote:It depends. The OS will split the task on the four cores. But we do not know yet (or maybe someone already does?) if AC can tage advantage of "all & full 4 cores"/ if multithreading within AC is optimized for dual cores only, no quadro, octo. I.e., if multithreading within AC is optimized only for dual cores- then graphical represenation would be [100]+[100]=200. 200 is FULL capacity. The maximum load AC will give on your 4 cores will still be 200, because it does not "recognize" your quadro processor. You will have only half-load on each core available capacity- [50]+[50]+[50]+[50]=200. I'm not That knowing about this techical staff, also it probly depends on what OS You're using. Maybe someone else could comment on this. Just wait first actual reviews on AC12 performance.
2008-06-19 12:47 AM
