2007-04-11 03:16 AM
  and yes, the topic is discussed over and over in this forum.
 and yes, the topic is discussed over and over in this forum.(..) ArchiCAD will not be a fully multi-threaded application at any time soon. This is partly because re-writing the ArchiCAD code to support multi-threading is a huge task, and there are areas where it would not cause a dramatic performance increase. Graphisoft will focus on the areas where multi-threading brings the most benefit.thus you don't need octocore (or even quadro) mac pro "at any time soon", because it's a big job for them. (if i think that ac on 8 cores would use 1/8 of the resources available-
 ).Transferring a 32-bit application to 64-bit requires reprogramming even the most basic functions in the software, therefore the change to 64-bit in business softwares will happen at a much slower pace than the rapid change from 32-bit processors to 64-bit processors in the Personal Computer (PC) industry.so mainly they are basing the answer once again on excuse, that it requres recoding ac + on a bad market practise "aww, the other business software developers are also slow on this". sorry, but that doesn't apply to other apps i use, ie, c4d, maxwell. yes, they are a different profile, but- whatever harware resources i give them- it's been effectivelly used. and that's the reason they REALLY are top software solutions. and the argument that archicad has 100x more lines of code can't be an argument.
2008-06-20 08:58 PM
2008-06-20 09:03 PM
Peter wrote:There are a lot of unknowns in this survey. How many respondents? (50 or 1000?) As I recall, this magazine is fairly pricey, so it is likely to be mostly circulated at large firms. Was it limited to one response/firm? You get 10 people at a large Revit firm answering, and it will skew the results. Further, it seems to be an English language magazine, so I suspect the results are heavily weighted towards the UK. Without knowing more about the survey protocol, I would be disinclined to give it a lot of credence.
It is not as if these figures were supplied by Autodesk themselves either. It feels like it's a pretty independent survey of software usage. The one thing I can't work out was if the survey was mainly from the larger practices or if smaller practices were equally represented.
It would also have been interesting to see the breakdown of usage for each continent. I would hope to see that ArchiCAD usage to be much higher in Europe!
2008-06-20 09:13 PM
2008-06-20 09:17 PM
LINZ wrote:Yes -- it is curious. You would think that even if they are hesitant to assist in the software development (for whatever reason), at least there would be some (if not a lot) of marketing support.
I think the interesting part of the discussion relates to the marketing strategy that Nemetschek will take with AC, as there is no evidence yet of any change since the acquisition.
2008-06-21 07:01 PM
Peter wrote:Are you sure that those are actual USAGE numbers?
I found an interesting article in the online version of Building Design. In a software survey they found that ArchiCAD usage at a disappointing 2%, whilst Revit is at 16% somehow!
How did that happen? ArchiCAD has been going for decades, Revit has been under Autodesks wing for 4 years or something.
2008-06-21 07:32 PM
2008-06-21 07:53 PM
Laura wrote:Not always. Do you consider how they use it or how they complete projects?Shivang wrote:Yes -- "Using" and "completing a project with" are two different things.
and use or success in Architecture means No. of Projects.
I think ! correct me if i am wrong.
2008-06-22 04:51 PM
Karl wrote:I've been doing some testing and thought I should qualify this earlier post. I do indeed see all 8 cores on my machine busy once in a while over the entire process of generating a section/elevation for example. Not necessarily a 'peak' period - but certain subtasks.
Yes, you will see 12 take full advantage of all cores at certain peak periods.
2008-06-24 08:09 PM
2008-06-25 12:29 AM
Jacob wrote:
This is how I see it. Less firms with Archicad=Less users of Archicad=More pay for proficient users of archicad. Simple. I'm looking at the numbers and it's high time we realize that this will not be the big program in the future. Wishing away facts never works.
