Window Schedules
I have been trying to create window schedules that automatically bring in the type of window (double hung, awning, etc.) but every time I create any type of window schedule it always gives me FIXED as the window type. I decided to run a test so I installed ArchiCAD on another machine that has never run this software and low and behold I could create the window schedule the way I wanted it. I downloaded all the updates including the library updates to try and make the software match on both machines. What I found is that if I load the latest library update (ArchiCAD Library 9.pla) the window types come in as FIXED. If I load the original library that was included with ArchiCAD (Object Library.pla) the window types will come in how I want them but I lose half of the windows that I have placed on the drawing, as well as the markers! Is there anyway to fix this or do I have to scrap the updated library and go back to the old one. I realize I can just export the schedule to Excel and manually make the changes, but I don't feel I should have to. Thanks for the help.
TomWaltz
What parameter are you reading for the schedule?
Tom Waltz
I'm not sure what you mean by parameters?
Also, I've noticed that when I add a new window the location (zone) will no longer show up for any of the windows within the same location.
