Window casing and sill mishaps
I came across a problem with window sills and casing that I find quite irritating. When removing the sill altogether, the bottom trim does not clean up properly with the side trims (see pict).
I found that a bit irritating as I stated before since in order to have the trims show properly in 3D and elevation I HAVE to activate the sill (even if I dont want to).
Someone here at the office who has been working with AC a bit longer than me suggested that he never used outside trims on windows, that he always modeled them from slabs and saved them as object. Isnt that a LOT of fiddling for a workaround?
Anyhow, ill be waiting for any insight someone might have.
Thanks in advance
-- AC 12 latest build on PC using the W1 Casement 12 library part ( altough the problem appears with other windows)
Erich
Graphisoft is aware of this issue and we are waiting for the next library update with this issue fixed.
Sorry to not be of more use.
Erich
AC 19 6006 & AC 20
Mac OS 10.11.5
15" Retina MacBook Pro 2.6
27" iMac Retina 5K
