Creating a curved roof?
I need to create a roof that is curved, arched, however you want to put it. Anyone know how?
11 Replies 11
Eduardo Rolon
Use Complex Profiles.
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
Guess I should have been a little more specific. Today was my first time using Archicad ever!
Dwight
So, be more specific.
Dwight Atkinson
Dwight
Is this a technical or conceptual roof?
How editable does it need to be?
Exactly how curvy/arched will it be?
Dwight Atkinson
I am trying to create a roof that is curved, starting at about 10' high at low end and arching to about 20' high at the high end. One continuous arc, that is a roof.
Sorry, can't edit my last post. It is a set of drawings done in autocad. I am training right now. One hurdle is to create a roof that is an arc. In autocad, 2d, just draw an arc on the elevation to represent the arc roof. I want to use Archicad to create a roof that is an arc.
Dwight
Yup. Complex profile - EJ is right.
You'll draw the curved roof section as the complex profile.
Then us it as a wall.
See the manual
The forum can't accept images posted tonite.....
Dwight Atkinson
Dwight
Djordje
Use the Vaulted roof tool as explained here:
http://www.graphisoft.com/archiguide_archive/ArchiGuide_Online_6o/issue15/roofs.html
If the smoothness of the arc is necessary, create the Custom Profile of the roof (the said arc plus thickness) and create the "roof" with the wall tool.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
