Window in split wall
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2008-02-11
06:24 AM
‎2023-05-26
02:51 PM
Rubia Torres
Problem I have is when I try to insert a window, it will only show on the bottom wall and therefore is cut off 1200 high by the wall on top.
Thanks in advance.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2008-02-11 06:54 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2008-02-11 06:57 AM
An alternative, if you have Door and Window Builder is to make 2 separate windows, the bottom one with no head frame, the top one with no sill (under Setout - Join Adjacent tab (glass joint option as required) )
HTH
Edit: or if you want to use the new-fangled gadgets, do as Dwight suggests.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2008-02-11 08:25 AM
e question which I couldn't find in 'F1" is, I need to have half the wall one colour and the other half brick, when a complex profile is created can it then be manipulated as separate elements??
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2008-02-11 08:30 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2008-02-11 09:12 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2008-02-12 01:44 AM
Thanks for the help.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2008-02-12 04:35 AM
Help will be appreciated
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2008-02-12 12:24 PM
Just a guess
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2008-02-12 12:52 PM
