Window inset and floor issue
Hello everyone, is there a way to solve the issue of the floor finishing being cut by the wall limits when you have a window inset? I can change priorities or layer order but I think there is an easier way (the floor skin is set to finish!).
Thanks in advance and kind regards
1 REPLY 1
I guess your issue is similar to what I had encountered here.
If it is the case, the base of the wall must be coincident with the base of the composite slab.
If not, give us more details about the components.
Paulo
