Window transparency in exterior elevations
How can I turn of window transparency when viewing exterior elevations. I don't want to see anything within the interior.
Thanks, Jim
TDabney
Thanks, Jim
Jim - Try Image>3D Window Settings>Transparency in Shading>Off - see if that works?
Tom
TND Architects P.L.L.C.
macOS 12.7
2021 16" MacBook Pro
Apple M1 Max
ArchiCAD 26/27
TDabney wrote:
Thanks, Jim
Tom
Thanks Tom, I tried that before with no luck, but now it works. Even when I hit rebuild. But I found out that I had to close the elevation, reopen it and then rebuild. Thanks.
I see your from Ketchum, I was there in 95-96, did a framing and finish project on 10 units. Ketchum is a beautiful place, its growing fast.
Jim
