Windows Keep Switching To Transparent
In 'View->3D View Mode->3D Window Settings' you can set the transparency to 'off', then the next time you make a view of an elevation, the windows will be opaque. However, if you left the transparency on when you created the view, there is no way to redefine the view so the windows are opaque.
I created two views of the same section -- one defined when transparency was on, and the other when it was off. Sure enough they each memorized their own transparency setting.
The question now is, How do you redefine the transparency state of a view? There is no transparency option in the Settings, and I have tried setting the transparency, popping up the settings dialog, then clicking OK, but it won't redefine the transparency. Currently, the only way I can solve this problem is to delete the original view and define a new one. However, I have a drafter who has completely annotated an exterior elevation, and has the transparency in the wrong mode. I would prefer not to lose all the associative annotation.
24 Replies 24
For copying Annotations from a one Section view to another, I usually set the vertical range of the section view with the annotations to limited and to a range from 0 to 1-feet. Viewing the Section I select the annotation (Usually a select all). Ctrl-C. Then view the "new" Section and Ctrl-V.
Laura Yanoviak
Jay-- I had success with opening the View from within the View Map, switching Transparency in Shading Off in the 3D Window Settings, opening the View Settings Dialog and hitting the button at the top that reads "Get Current Windows's Settings" and Save. The updated drawings within the Layout Book no longer have transparent windows.
Aussie John
Unfortunately Laura's technique doesnt appear to work for me.
Cheers John
[/size]
__archiben
it left me a little red-faced too . . .
http://archicad-talk.graphisoft.com/viewtopic.php?p=66647#66647
~/archiben
b e n _ f r o s t
Aussie John
Not to worry Ben - old timers are given some leeway
Cheers John
[/size]
Laura Yanoviak
This really did work for me -- it really did -- could it be one of those PC vs. Mac things???
Laura Yanoviak
Another thought -- have you all tried this post-hotfix???
__archiben
damn! they fixed it. it even works when redefining from a window that isn't the 3D window . . .
thanks for that laura!
~/archiben
b e n _ f r o s t
Aussie John
no luck here even though on build 966
Cheers John
[/size]
