‎2007-09-28
11:40 PM
‎2023-05-25
06:28 PM
Rubia Torres
‎2007-10-02 10:24 PM
‎2007-10-02 11:15 PM
Pete wrote:This is the method I've seen suggested, however, it seems like a bit of a "jury rigged" solution. This means that if I move the window I now have to move the opening or window frame as well. Not that it's a lot of work, but why add a step when it seems so intuitive to have the window penetrate a wall that directly abuts the wall on which the window or door is placed? There should at least be an option on the window or door objects to do this.
I add an empty opening of appropriate size & location to the interior "furring" wall. Yes, there is then a gap between the inner wall and outer wall or walls which I don't bother with.
In theory, instead of an empty opening, you could use a window frame & trim only with a jamb width that fills the gap. Kind of like modeling extension jambs.
‎2007-10-02 11:20 PM
‎2007-10-03 12:14 AM
it seems so intuitive to have the window penetrate a wall that directly abuts the wall on which the window or door is placedNot for me. My crew is actually framing two separate openings at different times in walls that are different heights many times. The opening in the interior studwall is not the same size as the window rough opening, depending in finishes, etc.. By calling out the interior opening and sill/head heights, it will get built right.
‎2007-10-03 12:26 AM
Pete wrote:That makes a lot of sense. I hadn't thought about it that way.it seems so intuitive to have the window penetrate a wall that directly abuts the wall on which the window or door is placedNot for me. My crew is actually framing two separate openings at different times in walls that are different heights many times. The opening in the interior studwall is not the same size as the window rough opening, depending in finishes, etc.. By calling out the interior opening and sill/head heights, it will get built right.
‎2007-10-10 10:21 PM
‎2008-02-07 12:59 AM
‎2008-02-07 11:27 AM
atlantex wrote:Why not put an empty window object or a niche object in the size/position as your window? Line them up and that should work.
I've created a custom profile of a 10" Concrete Foundation Wall with a Footing and a ledge to support the brick of the wall above. This wall is to be used for a basement. The problem is that when I place the interior framed walls (composite of 1/2" gypsum and 2x4" framing) around the foundation in the basement the windows and doors will no longer penetrate both the framed and concrete walls. The only solution I can come up with is to add the 2x4" framing and gypsum to the complex profile of the foundation wall thus making a single wall containing all of the elements so that the windows and doors will create openings all the way through. This works as intended for my basement floor plan. However, this creates a problem when creating a foundation plan because the foundation plan then shows the concrete, the framing and the gypsum instead of just the concrete because the materials of the complex profile cannot be broken up into layers.
So, my question then, is what do you generally do when designing a basement with windows through the foundation and interior walls? This can't be an uncommon issue so I'm assuming I've missed some obvious solution. Any suggestions are appreciated. Thank you.
‎2008-08-28 04:14 PM
