Windows and Door AC10
When I place a window/door right next to the other a line with the color of the Wall remains in the joint. If there's a way to change that? That makes the drawing look bad in lineweights
3 REPLIES 3
It depends on the window/door. Look for parameters that control "Wall Contours".
Eduardo Rolon
Yamil:
part of the answer
archicad-talk.graphisoft.com/viewtopic.php?p=62935&highlight=ganging#62935
Eduardo Rolón AIA NCARB
AC27 US/INT -> AC08
another Moderator
Mathew, if I turn of "Wall Contour parameter" in a "D4 Sliding 10 door" I loose some lines I need to show but doesn't affect those I want to get rid.
EColon, I try with the gaging but it doesn't look as it should. Do you find a way to deal with that? I think I should made different walls one next to the other to control the lineweight shown between door/window but will be primitive.
