Windows in 3D.
mukster
Using Archicad 24 on a MAC platform. Putting windows into a solid wall.  Some of the window stick way into the room, other windows do not. Checked all the settings, reveal is set at wall edge, still projects into the room
4 REPLIES 4
Eduardo Rolon
Please post a screenshot.
  • USA or INT version?
  • Regular wall, composite or profile?
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
another Moderator
mukster
mukster
USA version.
Eduardo Rolon
Post screenshots of the wall and window settings?
Usually that is caused by the reveal in the window (which you said you checked) or if the wall is a profile then the window opening location
AC29 US/INT -> AC08
another Moderator
