Windows not displaying correctly
While trying to update a drawing done in Archicad 9, using Archicad 11 the windows in elevation do not display correctly. The frames and sashes appear as one except when highlighted when selected. I don't want to change them all to Archicad 11 windows as it will take too long and I only want to make a few minor amendments - any suggestions?
4 Replies 4
I don't understand the problem. Perhaps a picture would help.
I seem to recall a problem with the change from 9 to 10 or 10 to 11 whereby the surfaces of the window frame and sash were deemed to be touching, and therefore cleaned up without a line between. Try changing the sash (inner frame) material to something different to the main frame material. You could make a copy of main frame material with a different name, that would do.
See if that works. Still a pain if you have to do this with all your windows, but you should be able to select them all and change the one parameter o.k.
Thanks will try as suggested but see attached for clarification
Thanks - the different materials technique worked!
